It is currently Mon Oct 19, 2026 8:57
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sun Aug 28, 2005 17:55
45 ms, u use SED1335 controller?
AC/DC \m/ =)
PostPosted: Sun Aug 28, 2005 17:57
How match does it take if use SED1335 controoller, and have u ever work with external CG RAM on SED1335, when M1 flag set to 1 (M1=1)?
AC/DC \m/ =)
PostPosted: Sun Aug 28, 2005 18:12
The 45ms was with SED1335. Haven't used the character features at all, only graphics.
PostPosted: Sun Aug 28, 2005 18:13
More fun in 160x128...
http://oms.wmhost.com/lcd/wet_optrex.avi
PostPosted: Mon Aug 29, 2005 7:51
320x240 pixels driven by SED1335...
Difficult screen to film, and with all the bus noise when there's lots of data flowing.
http://oms.wmhost.com/lcd/sed1335.avi
PostPosted: Mon Aug 29, 2005 9:43
Well, my program takes about 30ms to load 84*48 image thru USB, but eating up a lot of processor time, because of scanning bitmap image pixel per pixel. Is there any solution to that?
PostPosted: Mon Aug 29, 2005 9:53
It's best to convert the imagedata to the format used by the display before sending it to the controller and then just set the address to the start of the screen memory and send the data byte after byte in one go.
PostPosted: Mon Aug 29, 2005 10:02
This is pretty much how I convert 84x48 1-bit BMP before sending it to PCD8544 used in Nokia displays.
for(y = 0; y < 48; y++)
    for(x = 0; x < 84; x++)
        if (bmp[bmp[10]+(12*(47-y)+(x>>3))] & 1<<(7-(x&7)))
            buffer[x+(84*(y>>3))] = buffer[x+(84*(y>>3))] | 1<<(y&7);
PostPosted: Mon Aug 29, 2005 10:22
Pretty same as mine:
   For Line:= 0 to 5 do         // Repeat 6 times for 6 lines
    begin
     For x:= 0 to 83 do  // Scan horizontally
      begin
        for y:= 0 to 7 do       // Scan vertically 8 dots
           If BMP.Canvas.pixels[x,y+Line*8] > clBlack then
            templine := (templine shr 1) and $7F // shifting a pixel into a character
           else
           templine := (templine shr 1) or $80;
        tUSb := tUSB + LineToS(Chr(templine)); // Collecting characters into tUSB
        end;  // Here we have a whoile line of LCD data (84x8)
     Write_USB_String(tUSB);
     tUSB := '';
     end;
This works really fast. There is a thread that calls this routine every 50ms....I can't really understand why is so heavy for a computer to handle (30% processor time on WindowsXP-AMD Athlon 1.83GHz 8O )
PostPosted: Mon Aug 29, 2005 12:18
If you're calling it that often, changing ( Line*8 ) into ( Line shl 3 ) might help a little, depending on the language used.
PostPosted: Mon Aug 29, 2005 21:51
Nice demos.
PostPosted: Mon Sep 05, 2005 20:02
PostPosted: Mon Sep 05, 2005 20:14
PostPosted: Mon Sep 05, 2005 20:20
PostPosted: Mon Sep 05, 2005 20:23
