It is currently Thu Nov 12, 2026 2:01
PostPosted: Wed Oct 05, 2005 16:01
ok so i got me lcd today and i wire it i fire lcd smartie up and nothing happend :( but then i try lcd center and its kinda ok exept its very currupt ?
btw does lcdinfo support hd74480? (or whatever number it is :S)
PostPosted: Wed Oct 05, 2005 21:56
ok i know whats happening but how to fix it???
if i make it say "test" in lcdcenter it shows on screen as "4%34" wtf is going on???????? my paralell port is ecp is that a problem??
PostPosted: Wed Oct 05, 2005 22:08
Yes LCDinfo supports HD44780. You could try other LPT settings in the BIOS.
Also i'd triple check the wiring and check for proper grounding.
Which wiring scheme have you used?
PostPosted: Wed Oct 05, 2005 22:20
ok the wiring scheme i used is from www.electronics-lab.com
http://www.electronics-lab.com/projects ... ndex2.html
but i grounded pins 8-15 (i think thats what i did :P), and even before i grounded them i got the same problem... my display is a wintek(?) wm-c1604m says HD44780 compatible compatible, my wiring is ok i checked like 4 times :P
{edit} my bios doesnt have an option for epp ONLY :( maybe a windows setting?
PostPosted: Wed Oct 05, 2005 22:24
Use this one:
http://lcdsmartie.sourceforge.net/circuits.htm
whaddya mean 'i think i grounded 8-15' 8O
pin 18~25 on the LPT connector should be grounded, also make sure you have the portdriver installed, see that Smartie site.
PostPosted: Wed Oct 05, 2005 22:27
re-wiring...
PostPosted: Fri Oct 07, 2005 16:59
it works now,
how do i set up lcdinfo for hd74480?
and the robot lord said "01001111010011010100011100100000010110010100111101010101001000000010000001010010
010001010100000101000100001000000101010001001000010010010101001100111111 2" - Bender
Users browsing this forum: No registered users and 100 guests
