It is currently Tue Nov 24, 2026 21:07
PostPosted: Sat Aug 20, 2005 4:26
Ok people, ive read through the forums to try and find what i need to hook up this lcd that i have.. and im completely lost. I found the old nokia 3210 in my boxes and searched to see if i can hook it up to a lpt port. and i belive you can correct? i have the LPT connectors froma previous un completed mod, and i have wires etc... What i want to know is.. on the circuit diagrams there are diodes and other stuf.. Must i put them on? or is it optional?
Could somebody link me to a step by step? or write up a quick tutorial for me? not to loong as i dont wnt to waste yor time EG
1) remove lcd
2) strip 8 wires
3) connect to the 8 or 9 pins on the lcd
4) connect (X wire) to (Y pin) on the LPT port
and add in if i need to use anything else. and will the back liht work?
Thank you in advanced, Anarklov3r
 Post subject: nokia 3210
PostPosted: Sat Jan 21, 2006 12:04
hello there .. if you get a reply .. please contact me... im in the same problem... i found one to :)) and i want to connect it to my pc ...
i can see one problem... thers no controler on the diplay.. end i think u need one...
