It is currently Fri Jul 03, 2026 14:39
 Post subject: Winstar WG12864B
PostPosted: Wed Feb 08, 2006 18:41
Hello,
I'm trying to connect a winstar WG12864B (KS0108) to my PC. I followed the picture on the KS0108 page of this site to connect the display but it doesn't work. I only have tha backlight but nothing else when i try to display something with lcdinfo...
I think there may be an error in the connections...
Could somebody help me?? (a schematic of which pin to connect with the parallel port would be great :roll: )
For informations hera are some references :
the datasheet : http://www.winstar.com.tw/detail_view.php?pd_num=WG&pd_nu2=12864B
the picture I used to connect the display (the pin are not in the same order but I tried to connect the relevant one regarding to the datasheet) :
http://www.skippari.net/lcd/ks0108.html
Just another thing I only connected pin 18 of the parallel port to the ground (not 18 to 25), could this be a problem???
Many thanks in advance for your help!!
(Sorry for my poor english)
PostPosted: Wed Feb 08, 2006 20:08
Always triple cjeck your wiring, with multimeter preferably.
Did you also hook up the pot? If you adjust that does the contrast change?
PostPosted: Wed Feb 08, 2006 20:32
no the contrast doesn't change when i adjust the pot
PostPosted: Wed Feb 08, 2006 22:43
I'd suggest rewiring it, contrast should work. It could even be your display is working but you can't see it because you can't set the contrast correctly.
PostPosted: Thu Feb 09, 2006 7:34
Ok, I'll try this and I'll be back if there is still a problem :D
thanks
PostPosted: Fri Feb 10, 2006 19:04
the contrast is now ok but I still have nothing on the display with lcdinfo.
I tried to reinstall driverlinx and I can't launch lcdinfo anymore!! (could not open the driverLinx driver).
can someone help me please?? :oops:
PostPosted: Fri Feb 10, 2006 19:43
LCDinfo does not require driverlinx.
So the display appears to be ok, then the question is did you setup LCDinfo correctly for your display;
- select your appropiate driver and configure it's wiring,
- create a correct screens.xml file with correct designs
remember nothing happens when you fire up LCDinfo until you configure the driver and have some screens made.
