It is currently Mon Aug 24, 2026 12:54
 Post subject: Problem with KS108B
PostPosted: Fri Mar 31, 2006 1:06
Hey
The problem: The only thing that is being shown on the display when i start LCD-info is:
I have tried to get LCD-info 0.6 working on my KS108B LCD display but without luck. I know i have choosed the right driver and have also tested the build 17 and also build 18 drivers but still no difference. I have also tested the 2.0 WIN I/O drivers but that didn't help either. I have tested different wirings and lcdinfoscreendesigner.exe to get my LCD displaying the scripts but nothing at all.
As far as i know i have tested everything i can but im not the expert or the programmer of this program so i hoped you guys might be able to help me.
Thanks in advance.
PostPosted: Fri Mar 31, 2006 7:18
Looks fine to me! I think you didn't create any screens for your display size.
Edit the screens.xml, or look at the samples. All possible variables can be found in the log.txt.
PostPosted: Fri Mar 31, 2006 7:33
I thought the screens were pre-configured?
How do i load a sample? (pretty sure i know how but since better to ask to be really sure)
How do i create a screen then?
Here's how it looks like in my screens.xml file:
<screens>
<screenfile>84x48\winamp.xml</screenfile>
</screens>
<screenfile>128x64\bug.xml</screenfile>
<screenfile>128x64\mbm.xml</screenfile>
When using lcdinfoscreendesigner.exe, should the screens show up on my lcd at the same time as they are previewed in the small preview box in the the app?
PostPosted: Fri Mar 31, 2006 9:23
As you can see the first screenis made for 84x84. You need to create screens for your size (128x64) in the appropiate directories.
I can't comment on the GUI designer as i never used that. I always edit the .xml files manually.
PostPosted: Fri Mar 31, 2006 17:18
But how do i load the screens and start the scripts?
PostPosted: Sat Apr 01, 2006 0:58
Thanks for your help coorz, i managed to solve the problem but now there's another one:
I have tried to get Liquid-mp3 working for days now and finally today i thought i managed to get it to work but not quite. The display looks good for a couple of seconds after i start winamp with the liquid-mp3 running but then suddenly it looks like this:
Would really appretiate if someone could help me get this display working. And by the way, i have edited the default background by separating the upper field into two equal fields.
Thanks in advance!
EDIT: After posting i tested the new LCD-info were i also get these graphic bugs. So probably this isn't only something wrong with liquid-mp3. Well anyways, help is needed so if you guys have any idea why this is happening or what i can do to get rid of it please speak out. :)
PostPosted: Sat Apr 01, 2006 8:57
Typical KS0108 problems! I have similar issues.
Try the following:
- try other LPT mode (in BIOS)
- make sure you grounded pin 18~25 of the LPT connector; i always run a connection from LPT pin 18~25 to the displays GROUND.
- datacable should not be too long
- pull-up resistors on all datalines
