It is currently Fri Nov 13, 2026 15:07
PostPosted: Tue May 25, 2004 15:05
I have a Nokia 2280(CDMA), n wanted to connect its LCD to paralell port. Can someone please help with the controller used in this LCD or any working circuit.
PostPosted: Fri Jun 04, 2004 0:22
Go here for 2280 Service Manual
http://www.aussattv.oranged.to
That will give you pin outs and applicable voltages
Volts IO = 1.8v
Volts to power LCD 2.78v
Schematic calls out LCD as DMS03214 but this may be a dead end if it is a nokia reference number.
The controller part is harder if you cannot read it from the device on the LCD assy.
This LCD is 96x65 and also used in Nokia 3510. If you discover the controller type, please post it back here.
All the best.
PostPosted: Tue Apr 18, 2006 19:04
Hi, all.
The link above is broken.
Has someone any information about the Schematic e controller of nokia 2280 lcd?
PostPosted: Wed Apr 19, 2006 12:04
Yuri wrote:
Hi, all.
Yes it broken. At least for now.
You may have luck here http://forum.gsmhosting.com/vbb/showthread.php?t=176586
Looks like you need to load down multple RAR files. Should add up to around 6.6MB
PostPosted: Wed Apr 19, 2006 16:44
Moa,
Thank You by answering me.
I downloaded all docs and just found few informations about the LCD:
" RH-17 uses a 96x65 monochrome display. Dimensions for the display are 38.4 mm x 37.6 mm x 1.6 mm, with an active area of 31.15 mm x 24.78 mm. "
" LCD is controlled by UI SW and control signals.
Booster capacitor ( C302 1 uF ) is connected between booster pin ( Vout ) and griund. The capacitor stores boosting voltage."
Nothing more. I was thinking that the 3310 LCD and 2280 LCD was the same model, but the resolution is different. Does anyone know if the pinout is the same for both models? ( nokia 2280 has 8 pins ) The 2280 LCD it looks like the 3310 LCD very close.
Thanks all!
PostPosted: Mon Aug 06, 2007 22:28
Nokia 3510 LCD Pinouts: http://sandiding.tripod.com/ni3510.html ;)
PostPosted: Sun Mar 29, 2009 3:30
Here are the connections on the pcb side:
http://code.rancidbacon.com/images/nokia2280lcdcv1.jpg
