It is currently Sat Oct 17, 2026 5:46
PostPosted: Wed Jan 10, 2007 5:53
I have a lmg7420plfc-x Hitachi display that needs to be replaced. my questions are, are all lmg7420plfc-x displays the same,
is there a way to convert it so I can use a regular computer monitor instead.since the display is so small.
many thanks
PostPosted: Tue Jan 30, 2007 20:57
Almost everything's possible but as larger displays use different kind interface some work would be needed. You would need some kind emulation layer that emulates the controller used in the lmg7420plfc-x and receives the image data. Then this data would be scaled and written to the larger display. So if you don't know someone who would try something like this for fun you would probably need to pay someone to do it and if that makes sense depends of how much value the larger display would be...
All lmg7420plfc-x displays should be same.
PostPosted: Sat Feb 03, 2007 6:10
Thanks Henri
The reason I was wondering about all the lmg7420plfc-x displays being the same is mine doesnt have the pins for the interface and the chips. so if I was to get one that had them, would they work?
