It is currently Wed Oct 07, 2026 17:16
Post new topic Reply to topic  [ 74 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Mon Jan 26, 2009 6:53
Henri wrote:
Forgot to reply earlier that it works great here too. :)
Are these later versions supposed to open any window for keyboard control? The first time I tested I didn't have a touch panel connected and then I didn't find any way to control and stop the process other than killing through task manager.
No console window is opened as it's now fully touch input controlled.
While on topic; libgoom_plugin.dll, the visual effects plugin which is driving the audio visuals, contains a 3meg per track (and instance) memory leak. This can also be observed through vlc.exe with goom enabled while scanning through a playlist. Next vlcstream update will contain a replacement libgoom_plugin.dll with the leak fixed.
Leak originates through goom's heavy use of static variables.
PostPosted: Thu Feb 05, 2009 8:10
Updated the VLC Player:
Download
Adds a Playlist page and provides a replacement libgoom_plugin.dll
Finally got around to testing the OpenGL demos on an Nvidia Go 7400 based laptop, which to my surprise they did not work. They were Seg. faulting with an illegal instruction. A recompile with GCC 4.3.0 seems to have fixed the issue. All have been re-uploaded in to a single package here: Download
PostPosted: Sat Feb 07, 2009 16:47
Michael wrote:
All have been re-uploaded in to a single package here: http://mylcd.sourceforge.net/files/usbd480_demos.rar
Hello Michael
only fire,gl_distort and gl_mandel works here
 Post subject: Clocx plugin
PostPosted: Fri Apr 10, 2009 23:18
An output plugin for ClocX, an analog clock - http://www.clocx.net
Download
 Post subject: Re: Clocx plugin
PostPosted: Sat Apr 11, 2009 20:13
Working nicely here.
PostPosted: Fri May 15, 2009 14:04
Updated the Quake executables.
As well as adding GL modes of 480x272 this should also resolve the menu and gfx corruption in Quake3.
Requirements:
Quake 1: Demo or Full
Quake 2: Full install with the 3.20 update.
Quake 3: Full install with the 1.32b point release.
Download
Source
PostPosted: Thu Jun 18, 2009 17:19
Updated VLCStream.
Download
Added extra stuff here and there.
Should now work on VLC 1.0.0 and 1.1.0
edit:
Forgot to mention that Screencap and the VLC usbd480 output plugin have also been updated.
PostPosted: Tue Jun 23, 2009 9:44
Just playing with the new vlcstream here. Nice work. It's getting better every time :)
It might be useful to post the readme from the package here:
VLCStream
A standalone touch input video player for the USBD480.
As well as using this plugin to stream video directly to the USBD480, it may also be used in effect to stream your desktop, webcam and most
other video sources also, including DVB-T (digital TV) or any other TWAIN compatible device (digital cam).
Examples:
vlc.exe screen:// :screen-fps=20
vlc.exe dshow:// :dshow-vdev="Pinnacle WDM PCTV Video Capture"
Both dshow:// and screen:// are configured through vlc.exe.
Install:
Get VLC from: http://www.videolan.org/
Unpack vlcstream.rar to the VLC install location.
vlcstream.exe and vlc.exe should then be in the same directory.
libgoom_plugin.dll should be copied to vlc/plugins/
libgoom_plugin.dll resolves a per track 3meg libgoom memory leak.
Executing:
Run vlcstream.exe or through the commandline pass the media file to vlcstream.exe
eg; 'vlcstream "f:\path\to\file.ext"'
Controls:
Use a stylus. Touch stuff.
Btw, in this:
Examples:
Should vlc.exe be vlcstream.exe?
Also if anyone is running USBD480 firmware earlier than May 2009 (0.4) feel free to send me a message and we'll get you updated to the latest one. It can help improving the performance with these myLCD based programs. Or maybe it is already required.
PostPosted: Tue Jun 23, 2009 15:18
hmm.
Should actually have been in the usbd480_plugin.dll readme, but I just now see the file is actually missing.
PostPosted: Tue Sep 22, 2009 16:25
LCDMisc. for the USBD480
LCD Miscellany is a tool allowing one to write scripts to display stuff on Logitech LCD displays. LCDMisc for the USBD480 is a customization of the LCDMisc v4.4.3 scripts; adding an output plugin, touch panel control, full colour and resolution support for the USBD480, along with additional views and graphics.
http://mylcd.sourceforge.net/lcdmisc/index.html
PostPosted: Wed Sep 23, 2009 13:49
Looks great
PostPosted: Sat Sep 26, 2009 12:02
Wow, this definitely looks great.
PostPosted: Fri Oct 02, 2009 18:29
Updated VLCStream, my libvlc based media player.
This adds a new UI and fixes a touch control issue.
Grab it from sourceforge -> USBD480 -> usbd480_vlcstream.rar
(.rar contains several sets of icons. To use; rename icon folder to 'media')
PostPosted: Tue Oct 06, 2009 0:06
Hello Michael
touch control is not working here and for LCDMisc.
what drivers you use ?
PostPosted: Tue Oct 06, 2009 12:47
sos wrote:
Hello Michael
libusb driver with 0x700 firmware revision.
