It is currently Mon Nov 23, 2026 23:06
PostPosted: Sat Nov 07, 2009 22:47
Markus sent me these pictures of a Planar EL.640.200 SK display modded in his case and being driven by USB13700 controller board. Looks good to me :)
(click picture for a larger version)
PostPosted: Sat Nov 07, 2009 22:54
Couple days ago I also drew this schematic example how to connect a EL.640.200 SK to the USB13700 board:
http://www.lcdinfo.com/usb13700/misc/US ... .200SK.pdf
To my knowledge nobody has yet built a cable using this as a reference so please double check everything yourself in case there are any mistakes. My suggestion when doing the wiring is to connect as many ground wires between the display and the controller board as possible and keep the ground wires close to the signal wires.
PostPosted: Sun Nov 08, 2009 12:26
the shematics are right, but i prefer to get the power direct from the power supply and not from your board.
with conector 24 and a 100kohm poti against gnd it is possible to dimm the display and prevent burn ins. you can see the pot knop on my pictures below the front-usb conector.
thanks again henri for your great support and this great little board!
markus
PostPosted: Sat Dec 19, 2009 20:00
Hello Henri
I wired up my EL 640.200 and it works perfekt, thanks for the schematics. :D
My conector 24 is also conected with a "poti",thanks mash.m for the Tip.
Edit:
Detail connected Potentiometer
Some more Pictures are HERE
