It is currently Tue Oct 06, 2026 9:34
 Post subject: DG-12864-53 Help :)
PostPosted: Sun Sep 06, 2009 2:59
Hi everyone,
I´ve found this LCD among some old stuff at home. I remember that I got in junkyard (a day-trip with my old men) but I can´t remember what was attached to it, if to a UPS or some type of printer. Meanwhile I forgot it and now I “re-found” it and I was wondering if it possible to put it to work. I´m no electronics expert/technician but I believe that I can make it work but I need help.
This is what I found (Googled) about it:
- It´s a 128x64 graphic display;
- DG-12864-53 from DATAVISION (in the PCB there are two references : DG-12864-53 and 1264-45A S2FTLY-AP on a sticker);
- It uses KS0108;
- It´s attached to some controller board that I couldn´t find any (valuable) references in the internet – P306A, Phico M-0, 0235 94V-0, ELECTRONICS FOR IMAGING Z18 USB UIB.
In the DATA VISION website I “decoded” (http://data.s520.com/en/code.php) the graphic display reference DG-12864-45A S2FTLY-AP:
DG – Graphic LCM;
12864 – Graphic resolution 128x64;
45A – Series No.
S2 – LCD mode Silver gray, STN;
F – Polarizer Mode Transflective;
T – View direction Top View (12H);
L – Backlight LED;
Y – B/L Color Yellow-green (EL,LED).
Bottom line, what I want is to connect it and use but I can´t find a cable (or schematic) suitable to do that. I´ve found some on the forum but I don´t know if a “linear” adaptation can do the trick and I´m afraid to blow everything up (between other things) :P
The board where the display is attached (solded) has a connector (3M3793) that I believe that could be used to connect to the PC (trough USB, because the board also have an USB controller – CYPRESS AN2131SC) but the only reference I got to this is in some L-Band Synthesizer project http://www.teledynemicrowave.com/pdf_broadband/9717_L-Band_Synth_without_Aux_1205.pdf.
Can anyone give me a hand or point me to the right direction?
LCD images
Product S/N and identification
PCB identification
Back view
Sticker with references
Some voltage reference (I believe that is to the LCD backlight)
Some ICs near the USB controller
Some IC on the controller board
Back view from the graphic display
An IC that I think is the negative voltage generator
Full module back view
Top of the module (on the controller board)
USB controler
References on the graphic PCB
Module front view
Some PCB references
Internet references
http://episteme.arstechnica.com/eve/for ... 6740919555
http://www.mikrocontroller.net/topic/140487 - In German, I need to use an online translator.
Data Vision website
http://data.s520.com/en/lcm_02.php and http://data.s520.com/en/lcm_02_1.php?P_Id=30
PostPosted: Sun Sep 06, 2009 22:05
it looks like a KS0108 based lcd
PostPosted: Wed Sep 09, 2009 2:16
OK, working on that basis a using Henri diagram (http://forum.lcdinfo.com/viewtopic.php?t=286) for Crystalfontz (CFAG12864B-TMI-V), I come out so far with this Image and now I have serious doubts about the remaining connections (pins 2, 3, 6, 17, 18 an 19) because the supplying voltage its different.
Also I find out that the IC (SCI7661M0B) Image I thought it was a negative voltage generator is really a "booster that generates a doubled output voltage (-3.6V to -12V) or tripled output voltage (-5.4V to -18V) from the input (-1.8 to -6V)" (and I think is not only a booster but also a negative generator - like I said earlier, I´m a noob) - SCI7661M0B Data-sheet http://www.datasheetarchive.com/pdf-dat ... 174650.pdf
Those are the voltage and pinout table Image , can you give me a hand filling up the gaps I have? Please?
PostPosted: Thu Sep 10, 2009 23:56
Hello again,
Looking at the main existing schematics for KS0108, I adapted almost all the connections (and I think they are correct)... Image
But I don´t know one thing:
- What value for the variable resistor should it be used (since Vee= -10v and regarding the general voltage table) - perhaps 20k?.
Thanks again.
 Post subject: Re: DG-12864-53 Help :)
PostPosted: Mon Dec 13, 2010 9:56
you can get the lcd modules datasheet easily by google.
Users browsing this forum: No registered users and 88 guests
