It is currently Mon Nov 16, 2026 21:41
 Post subject: phico lcd
PostPosted: Sun Mar 14, 2004 11:20
ok i have a module here. Not sure hte model of the serial bay, but the lcd is a phico d-0 94v-0 and has p110-2. I got it from college and it's out of an old server, but wasn't able to test it out and stuff.
the serial bay is really old so it requires that u plug into the old style motherboards serial port connector *eg it doesn't have a serial connector it's just like a floppy connector thing*
I'm not too interested in getting the serial bit to work more interested in soldering up a pcb to get the lcd display to work...
if any1 knows where i can get it done... that'd be cool! :D
*edit* btw, the serial bay has got 2 panasonic chips on it, with this model number TL PCF8574T TC3494.1 and it has 3 switches on it, made from digital and was made in 1996 *shrugs not sure if that'd help*
PostPosted: Sun Mar 14, 2004 23:39
PCF8574 is a I2C bus 8-bit IO expander:
http://www.semiconductors.philips.com/pip/pcf8574p
Have any pics of the thing ?
If it's a normal parallel display with this I2C backpack you might be able to remove the backpack and use it as normal parallel display.
PostPosted: Mon Mar 15, 2004 15:28
hmmm i will have pics of it up soon.... maybe tomorrow or the day after... sorry
would i be able to get the drawings for soldering up the panel? if any1 has the drawings... i would have NO idea how to find out what pin is what... *n00b at this sowwie*
PostPosted: Sun Mar 21, 2004 13:32
is there some sort of way to know how to wire my lcd up to the parrallel port or not?
it's a phico d-0 94v-0
any ideas?
i still have not been able to get pics of it, my digi cam has recently kicked the bucket and friends don't have one...
PostPosted: Sun Mar 21, 2004 18:04
I don't know what that "phico d-0 94v-0" tells but it's not the model number.
Did a search for "phico" in this forum and found this:
http://www.skippari.net/phpBB2/viewtopic.php?t=170
You can see the same string in the display there.
Based on your description I believe your display is a parallel display with a backpack but more information would be needed. Like the controller chip etc. Is it character or graphics display ?
Any other markings on the display or on the chips ?
PostPosted: Tue Mar 23, 2004 8:03
it has p110-2 and 9647on the lcd
i have 2 of them and both of them have those 2 on em... but then i think there is a manufacture number on it.... one has 9647 and the other 9803
There is a chip on the lcd but it doesn't have anything on it...
it's a datavision that's all i know....
it might be a serial display as it only has 16 connectiosn to the lcd and it used to connect to the serial port of the old motherboards.... *shrugs*
The backpack is made by digital, has the two PCF8574T, and wat looks like a motorola chip F132 XAA752.
there are a few numbers that are common on both backpacks 50-23593-01 E01 and on a sticker -01 B01
PostPosted: Mon Mar 29, 2004 10:16
www.geocities.com/mmawr/pict0082.jpg
www.geocities.com/mmawr/pict0083.jpg
www.geocities.com/mmawr/pict0084.jpg
www.geocities.com/mmawr/pict0085.jpg
unfortunately you will have to manually paste the links into a new browser window as geocities does not allow forums to have direct links to the users...
PostPosted: Mon Mar 29, 2004 16:40
Didn't get much new info from the pictures...
But if it has 16 pins it might be a HD44780 compatible display.
PostPosted: Mon Mar 29, 2004 16:56
hmmmm :(
really want to get these to work damnit.... only want to display like cpu usage and memory usage and winamp song on it... :(
PostPosted: Wed May 19, 2004 7:08
Greetings
PHICO are a PCB manufacturer and product assembler in Taiwan who build product for many brands. You will see their brand silk screened to the PCB rear of many different brands of LCD.
I have a Grand Pacific Optoelectronics (GPO) LCD with the PCB silk screen marking
PHICO D-0
0323 94V-0
The PHICO D-0 94V-0 number is common to a lot of different looking PCBs. So the particular part board design is likely to be in the 7 segment fonted number, 0323 in my case. I have not found a cross reference for these numbers and likely to only be available in-house.
I am fortunate that GPO specified further markings be on their build.
In fine black print, probably from an assembly line inkjet. I get the model details. The most telling is the marketing model number GPC162-556-NYPBELY
Data sheet for which says 16 x 2 line Character H44780 compatable (but always slightly different) w/ LED backlight.
Hope this is useful.
PostPosted: Wed May 19, 2004 11:07
Here is an explanantion of the 94V-0 numbering on Phico PCBs
(PCB flamability rating)
"The DataVision logo is from Data International Co., LTD of Taiwan.
PHICO is a PCB manufacturer based out of Taiwan and China. PHICO is one
of the sources used by Data International for fabrication of our display
PCB designs. 94V-0 is the flamability rating of the PCB material. P60-1
is the version number designated by Data International, and does
correspond to a DG-12232 display."
Quote courtesy of www.eio
PostPosted: Sat Sep 04, 2004 21:52
greetings.
i have two of these LCD displays myself, and would love to get some more info on them.
here's some info i found on the forums at extremeoverclocking.com - there're a couple of thumbnail images that show how to hook up a parallel LCD display to the printer (parallel) port on your PC.
like i said, i've got two of these things, so i guess i'll end up experimenting with one, and if i end up blowing it up... oh well.
hope this helps.
later on,
Bubba.
