It is currently Sat Oct 10, 2026 5:41
PostPosted: Tue Apr 13, 2004 10:44
Hello, maybe anyone has dos driver or know how to connect Nokia3310 lcd to use with MPXplay (dos mp3 player)... this player support standart 20X2 lcd displays, but what about Nokia3310 lcd display?
PostPosted: Thu Apr 15, 2004 11:41
You could ask this in the MPXPLAY board and maybe someone there would be interested.
I know how this could be done and it's not too difficult. I once added support for the Noritake GU128x64-800 VFD to MPXPLAY so I know how it's done (I also sent the source code to the MPXPLAY developer but it turned out he had already added support for this display using the example source I put in the development forum. ;) )
But I don't think I have a DOS development environment with Watcom compiler setup at the moment.
I'm not promising anything but I might look into this sometime later.
PostPosted: Sat Apr 17, 2004 18:57
HENRY >so I know how it's done
Could you write how could i do this?
PostPosted: Sun Apr 18, 2004 0:01
Well basically you first download the mpxplay source code and then look into the display\lcd.c file. In the end of that file there are empty functions where you can define your own displays.
Users browsing this forum: No registered users and 165 guests
