It is currently Tue Jun 30, 2026 3:42
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Nov 14, 2002 1:54
No problem. i hope that you got them. one is of the make-shift circuit. the other is what i get on the screen. i hope that is a simple error. thanks again. :lol: :!: :D :) :wink:
PostPosted: Thu Nov 14, 2002 8:23
Here they are:
I rotated this one to fit better on the screen.
PostPosted: Mon Nov 18, 2002 11:07
I've made a schematic for the Crystalfontz CFAG12864B-TMI-V that might be of some interrest to some of you;
Wiring is the same as Heri's original schematic, so all of his software should work.
Creator of LiQuiD-MP3
PostPosted: Mon Nov 18, 2002 14:47
Great, I'm sure it will be usefull. Your's even seem to have a proper reset generated. My schematic is just a minimal configuration needed and it doesn't have anything "extra" stuff included.
PostPosted: Tue Nov 19, 2002 1:50
so will i need all of that extra stuff?? i just connected the reset dierctly to +5v. i don't see what difference that would make, or would it?
PostPosted: Tue Nov 19, 2002 1:59
hey i still can't get any software to run on win2k. to test the software i have to boot in to win98. you guys say that it should work. i downloaded the DLPORTIO and installed it on win2k and it says that there is no driver running. when on 98 i just installed it and it recognised the driver. what an i doing wrong? =I
PostPosted: Tue Nov 19, 2002 5:01
nope i tried reinstalling and still i get the same error. i am admin on my win2k PC what could be the problem? could it be another piece of software? i haven't installed another piece of HW on the parallel port. i use USB => anyhow i checked the connections. everything is connected with the solder in contact withe the points. i really dont want to re-solder the whole thing in fear that it would turn out like the contrast pin. 8O
PostPosted: Tue Nov 19, 2002 10:13
You shouldn't need the extra parts. The parts in Zotty's schematic give a slight delay for the reset signal so that the controller is reset after voltage is applied (at least this is what I think they do).
Have you tried the other DLPortIO installer I mentioned here:
http://www.skippari.net/phpBB2/viewtopic.php?p=325#325
PostPosted: Tue Nov 19, 2002 13:25
Yep, that's correct ;) When you turn on the display, the condensator (C1) needs a few ms to charge. These few ms's give to KS0108B more than enough time to do a proper reset.
You don't need C1 and R2, but if you use them, you'll have the assurance that your display is reset at power-on.
PostPosted: Wed Nov 20, 2002 2:54
ok the different version of the dlportio drivers did work and now i can open the software. the only problem is that the LCD doesn't display anything. i will restart my PC and see if it will work with the LPT on normal mode.
PostPosted: Wed Nov 20, 2002 14:49
With what software ? LCDInfo, Ks0108 test from the development forum, MarkusM's utilities or something else ?
PostPosted: Mon Jan 27, 2003 5:49
hey i am back.
i finally found some spare time and money to build that circuit. now the LCD does not display anything. i think that it has something to do with the paralell port type settings in the BIOS. what should they be? EPP(1.7, 1.9), ECP, Bi-directional, normal. i have tried many of these and i cannot remember what i got. what would you reccomend i set it to? oh and i tried every LCD program that i have LCDinfo, ks0108 test(both the one from your site and the one that you sent me), GIF animation.
PostPosted: Mon Jan 27, 2003 10:49
With my KS0108 code there is only writing to the parallel port so I don't think the parallel port mode should affect much (it's always possible though). I'm using ECP with my displays and haven't had any problems yet.
If the parallel port settings don't make any difference and you have the DLPortIO driver working I don't know what else than wiring could be the problem.
Now LiQuiD-MP3 has also KS0108 support if you wan't to try: http://zapour.student.utwente.nl/schijf ... ic.php?t=5
 Post subject: Ya
PostPosted: Fri Jan 31, 2003 7:39
I'd like to know more about this serial splicer type thingy. (the one from Robotstore)
Does this work? or is it even possible?
This is in relation to my thread in the "LCD" Forum
Cheers.
PostPosted: Fri Jan 31, 2003 9:15
I think you could get the serial converter from Robotstore working with some tinkering and programming. But I don't think that's suitable for interfacing LCD's to computer, especially graphical ones as the speed mentioned (9600bps) is very slow.
