It is currently Mon Aug 03, 2026 21:18
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 17 posts ]  Go to page 1, 2  Next
 Post subject: Winamp v3?
PostPosted: Wed Nov 20, 2002 9:45
I don't seem to be able to get the Winamp screen to work. Even though winamp is running the LCD will not dispaly info.
Is there a plugin for winamp I am missing? Or does this preview version not work with Winamp Version 3?
Marty
 Post subject: Re: Winamp v3?
PostPosted: Wed Nov 20, 2002 15:06
Marty
LCDInfo doesn't support winamp3 at the moment. I haven't found a good way to get the information from winamp yet.
Last week I found this component for winamp3 but haven't had time to look at it:
Winamp 2.x Plugin Manager for Winamp 3 http://members.telocity.com/~schweitn/wa3/wa2mgr
If someone knows how to retrieve this information from winamp3 you could support the development of LCDInfo by sharing your knowledge.
PostPosted: Thu Nov 21, 2002 1:45
There is a plugin for winamp 3 that runs as a winamp 2 pluging , the api is based on the plugin manager from the link you gave, i found this information in the LCD Smartie page a person named Julian had made a pluggin to make winamp3 work with smartie , so if you talk to it maybe he can help , it's adress come on the Zip file from the pluggin i downloaded from the lcd smartie page :
http://www.rendo.dekooi.nl/~basiep/smartie/
the email and iformations are:
Copyright [-JMH-] (julian) 2002
You can distribute it free,so long you dont make any!! changes on it.
Please tell me your oppinions and suggestions to this plugin at 57223751 or julianhille@gmx.de.
Hope this can be usefull
SAmtech
PostPosted: Thu Nov 21, 2002 17:39
I have made a textfile support to LCDInfo that allows getting winamp3 stats using these plugins. New exes including textfile support: http://www.skippari.net/lcd/sekalaista/ ... 3_exes.zip
Extract the exe found in the zip over a 0.3.2pre12 installation. More info about 0.3.2pre12: http://www.skippari.net/phpBB2/viewtopic.php?p=331#331
First install this one:
Then this plugin from LCD Smartie's page:
http://reisemobile-rohmann.de/temp-10da ... plugin.rar
Local mirror: http://www.skippari.net/lcd/forumstuff/ ... plugin.rar
Follow the instructions found in the rar package:
For winamp3 u need:
http://members.telocity.com/~schweitn/w ... index.html
there is a file called Winamp2 PLuginmanager for winamp3
Download and install it.
The put the two files which comes with this mp3.txt Help file into your winamp3 folder.
smartie.dll
gen_smartie.plugin.dll
Start Winamp3 or restart it if it was running while your installation.
Go to your Setting window in Winamp3 and choose "Winamp 2x Plugins".
Choose "Plugin Path" and choose the path where you put smartie.dll and gen...dll and add them.
Then go back to "General Plugins" and start the "MP3 Info - Plugin for Smartie".
After that u dont have to configure it.
This plugin writes the information to a text file to C:\mp3.txt.
LCDInfo settings I used for testing:
Line0=
Line1=" $textfile(c:\mp3.txt,1)$"
Line2=
Line3=" $textfile(c:\mp3.txt,8)$ / $textfile(c:\mp3.txt,9)$"
Line4=
Line5=" $textfile(c:\mp3.txt,11)$ $textfile(c:\mp3.txt,12)$"
Line6=" $textfile(c:\mp3.txt,13)$"
Line7=
Thanks for bringing this plugin to my attention, samtech.
I haven't checked but maybe there is even a native winamp3 plugin that writes the info to a text file. This way the Winamp 2.x Plugin Manager for Winamp 3 wouldn't be needed.
Still I would prefer a solution that didn't require using the intermediate text file but I guess this solution will work until I have time to do that. Maybe someone will write a component for winamp3 to allow external programs interface to it. I can always wish. :)
 Post subject: NT versions
PostPosted: Fri Nov 22, 2002 23:11
Hi Henri,
Could you please post the NT version of LCDInfo wthat supports the text fille thingy.
Marty
 Post subject: Re: NT versions
PostPosted: Fri Nov 22, 2002 23:25
Guest wrote:
Hi Henri,
Marty
The NT exe should also be in this file: http://www.skippari.net/lcd/sekalaista/ ... 3_exes.zip
Have you got the winamp3 support working ?
PostPosted: Fri Nov 22, 2002 23:35
Henri,
There is a native Winamp3 text file output thing, Search for 'Info File'.
It makes a text file with the following:
The output file currently has this format:
<Winamp version>
<Artist>
<Album>
<Title>
<Genre>
<Year>
<Comment>
<Track Number>
<Length of track (seconds)>
<Position of file in playlist>
<Number of files in playlist>
<playstring (path to file)>
<UNIX timestamp of playing start>
<Component Version String>
Hope this helps.
Marty
PostPosted: Fri Nov 22, 2002 23:59
Guets wrote:
Henri,
Ok, I searched and installed Info File and it writes the info to a text file that was accessible in LCDInfo. So you can use this component too. But Info File doesn't write the time information to the file so if you wan't those you need to find something else like the plugins mentioned in the earlier posts.
 Post subject: Link down
PostPosted: Wed Jan 29, 2003 2:57
This link is down...
 Post subject: Help me plz
PostPosted: Wed Jan 29, 2003 3:13
"and choose the path where you put smartie.dll and gen..."
path ? what path ? I only extract them to W3 folder... then in the Plugin Path i add the location off the dll files but nothing happens.. (sorry about the poor english.. i'm brazilian and i'm not expert in english)
PostPosted: Wed Jan 29, 2003 11:49
These problems should be fixed when I get the winamp3 component for LCDInfo ready.
 Post subject: when
PostPosted: Sat Feb 08, 2003 22:52
and when ur going to finish it ?
PostPosted: Sun Feb 09, 2003 11:19
The new winamp3 plugin will be made for the next LCDInfo version. I'm not sure when the next version is ready as it depends of how much time I will have to spend on it. It could be after next weekend or then next month.
 Post subject: Link does not work!!!!
PostPosted: Sat Feb 22, 2003 9:40
If you want to dl WinAmp 2.x Plugin manager here it is:
http://www.winamp.com/components3/detai ... tId=118230
PostPosted: Sat Mar 15, 2003 16:28
hi its an honor for me that you all talking about my plugin ;))
i just want to say there is a new version coming out in some days...
atm my webadress is: hilleware.team-oldskool.de but it will change in some days too a notification will stay on old adress!
and thanks agaion for using my plugin ;)
Users browsing this forum: No registered users and 36 guests
