It is currently Fri Oct 23, 2026 3:07
PostPosted: Tue Apr 26, 2005 21:07
I got CU20045SCPB-T23A on parallel port wired on the parallel port, it looks exactly like this one on the photo on page: http://forum.lcdinfo.com/viewtopic.php?t=696
Which version of LCD_Info and driver should I use? It's running with Winamp 2 using version 0.6 build 18 and the driver : http://www.skippari.net/lcd/alpha/noritake_t23a_driver.dll
but it displays only 1 line "test string" and WinAmp info in the second line, two next lines stey empty... Please help
Greets,
Ogesto
PostPosted: Wed Apr 27, 2005 14:59
Sounds like you have it working you just need to edit the screens to match your needs:
http://forum.lcdinfo.com/viewtopic.php?t=471
PostPosted: Thu Jun 30, 2005 19:22
Just been messing with this screen, pretty nice.
Heres a quick sample winamp screen to get you going.
Works with winamp 2.91 and winamp 5 for me
<screen>
<name>Winamp2</name>
   <item type="plugintext" x="0" y="0">
      <scrolltype>center</scrolltype>
      <textpos>left</textpos>
      <fieldsize>20</fieldsize>
      <varid>Winamp2.Title</varid>
      <refresh>500</refresh>
   </item>
   <item type="plugintext" x="3" y="1">
      <scrolltype>none</scrolltype>
      <textpos>right</textpos>
      <fieldsize>6</fieldsize>
      <varid>Winamp2.TrackPos</varid>
   </item>
   <item type="text" x="10" y="1">
      <fieldsize>1</fieldsize>
      <textdata>/</textdata>
   </item>
   <item type="plugintext" x="12" y="1">
      <varid>Winamp2.TrackLength</varid>
   </item>
   <item type="text" x="0" y="2">
      <fieldsize>7</fieldsize>
      <textdata>Track- </textdata>
   </item>
   <item type="plugintext" x="7" y="2">
      <fieldsize>5</fieldsize>
      <varid>Winamp2.PlaylistPos</varid>
   </item>
   <item type="text" x="12" y="2">
   </item>
   <item type="plugintext" x="14" y="2">
      <varid>Winamp2.PlaylistSize</varid>
   </item>
</screen>
