It is currently Wed Jun 10, 2026 14:31
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
 Post subject: Graphics Display
PostPosted: Fri Jun 24, 2005 17:55
How to controll a graphics display (HD61830 Controller IC) How To put pixels or characters.
PostPosted: Sun Jun 26, 2005 12:32
With a controller?
PostPosted: Sun Jun 26, 2005 17:13
What's the model of the display?
PostPosted: Sun Jun 26, 2005 18:16
LM213XB (hitachi)
PostPosted: Mon Jun 27, 2005 2:14
Don't know if you have this spec sheet or not, but...
http://florent.bedoiseau.free.fr/HWare/ ... M213XB.pdf
Hook up as shown with the following:
Pin 3 is contrast: 10K pot, one side to VEE, one side to VDD, center to VO(Pin3)
Pin 4, 5, 6 and 15 goes to LPT 1, 14, 16 and 17. I don't think it matters which goes where as you can set this up when you choose the LC7981 driver for your display (same as the HD61830)
Pin 16 Reset: tie this through a 10k to VDD (Look at Densitron HD61830 pdf file)
Pin 17 VEE: should be about -10.5vdc according to data sheet.
PostPosted: Mon Jun 27, 2005 11:13
Thanks but I dont know what kind of program can I use, I use LCDsmartie for the character displays, but for graphical displayI dont know
PostPosted: Mon Jun 27, 2005 14:25
You would use LCDinfo of course :D
The forum you are posting on right now.
 Post subject: LCDinfo
PostPosted: Mon Jun 27, 2005 19:22
Where can I download the new version, because the old version dont suppert this controller!
 Post subject: Re: LCDinfo
PostPosted: Mon Jun 27, 2005 19:58
Just download the latest version. I believe it lists the LC7981 controller, which is the same as the HD61830.
PostPosted: Tue Jun 28, 2005 9:53
Can you give me a link, where???? Because I dont Find (lc7981 and hd61830 controllers
PostPosted: Tue Jun 28, 2005 17:44
http://www.skippari.net/lcd/alpha/lcdinfo_test.zip
 Post subject: LCD (LM213xb)
PostPosted: Tue Jun 28, 2005 18:39
I see the graphic on the LCD only?!
If I want to make another picture Can I paint in "windows paint"??
How to make animations?
This the the LM213XB (256*64 pixel)
opps how to paste a picture? [/list]
PostPosted: Tue Jun 28, 2005 18:43
I can paste picture only from a webpage[/img]
PostPosted: Tue Jun 28, 2005 19:38
A good place to get started is here:
Explains how to get started with screens and editing them.
PostPosted: Wed Jun 29, 2005 13:44
Hi one~zero
I have got a little problem I dont see anythink with this version. in the later version I can see everythink (not on the display I dont connect it) on the windows what is the problem?
