It is currently Mon Oct 05, 2026 7:51
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jul 29, 2005 17:10
Thanks a bunch!
- Rexxie
PostPosted: Tue Nov 22, 2005 21:33
How do you have to install this one? version 0.3.2 works perfect here.
I'm n00bz0r here please don't shoot me :)
if any1 can help me on msn messenger, that's even better :)
Wilz0r
PostPosted: Sat Feb 10, 2007 0:08
Some new features :) so I believe that this can be considered a new build so...
Build 20
added:
-BarGraphs (By Henri, implemented by me and fixed some things)
-Sliders (By Henri, implemented by me and fixed some things)
-Histograms (already existed, but were undocumented)
-PieGraphs
sometimes has a problem when closing the program, but I wasnt able to reproduce it yet, so I dont know the causes yet, any information will be welcome.
LINK
edit: added some more details that I remembered, Henri should get some credits, because he did some of this
PostPosted: Sat Feb 10, 2007 2:08
Wow, great to see some life in this.
Could you also post the source so that I could have a look how you have implemented things ?
PostPosted: Sat Feb 10, 2007 2:14
Sure here you go :)
There may be some coding errors, since my C++ knowledge is not very much and I could not understand all the code that you wrote.
LINK
edit: btw, use the latest SDK I have updated it a little
PostPosted: Fri May 11, 2007 16:25
Hello,
Here I am to announce that I've been working on a half-developed feature of lcdinfo, TrueType text, Henri started it some time ago, and for the last days I started to work at it... static text is now possible with TrueType fonts, just needs some adjustments and it will be ready, then I'll add PluginText too and then release a new build, if Henri agrees of course ;)
PostPosted: Mon May 14, 2007 13:25
Sounds good :)
Of course I agree to something like this. That's the idea of having the source code available ;)
Maybe if there's interest it would be a good idea to put together a more organized source repository and even look into developing LCDInfo further into a cross platform tool and adding more features.
PostPosted: Mon May 14, 2007 20:21
its ready ill upload it in a few hours.
I agree that we could cross-platform it, but the way it is it would be too hard, there is too much windows dependent code, like the true type fonts, you started it with opentype, but since i couldnt get it working with it, I used some windows API its easy and works, of course has its problems of the cross platforming, one good thing was porting it to .net (the libs I use are from the ms sdk win2k3(or something like that :P)), but in .net there is come code that needs to be fixed the deprecation etc.
anyway i like the idea, and by the way, if anyone has new ideas please feel free to post them, ill try to put them on if i have the time, if you know how to do it go ahead :D I would be very happy seeing someone else developing this software.
PostPosted: Thu May 17, 2007 9:38
I have to make a small project on my studies. Destination is to show something on PCD8544, and it is that what make LCDInfo. I already know haw to use LPT port, I have a specyfication for this LCD, but I can't show anything on the screen. I tried to undestande how LCDinfo works by reading source, but my knowladge is quite poor and failed. For now I have some functions that set pins onLPT axactly as I want, and I can write 8 bytes (and send in this way one whole byte of command or data to LCD). But I can't see any response. Is there something out of specyfication, that I should do, and I don't. Mayby someone can send me examle what to send (exactly how to setpins) to get something show on LCD? I'm using c# and inpuout32.dll to comunicate threw LPT.
Will anyone help me :?: :)
PostPosted: Thu May 17, 2007 18:02
Here it is the Build 21 now with the wished TrueType Text.
Have fun.
BUILD 21
SOURCE
garet4 read the driver source, what you need is there ;P
PostPosted: Tue May 17, 2011 9:32
Thanks a lot! You helped me out big time! :D
You can switch encoding parameters of end files such as example frequencyp
wav to mp3 converter free download
